4.3l backfires through carb and runs rough
moneypit23
just replaced the pickup coil in the distributor and boat ran great for bout half an hour. then i started it back up after a short swim, was running great planned out fine then just fell on its face and now will hardly idle. it backfires throught the carb and sounds like its got a massive vacuum leak. was going to check the timing but found there was no timing tab so im working on that.... any other ideas would be very helpful!!!
Re: 4.3l backfires through carb and runs rough
Ayuh,... Water in the fuel,... Check the filter...
moneypit23
ok ill go with that since i havent checked it yet, but why all the sudden?
marinetech77
Ethanol based fuel...need we say more.It's taking quite a toll on everyone.Start with the basics first.
6meter
How did you time it after you had the dizzy out? Recheck your work.
Ayuh,... Every Problem has a starting point, don't it,..??
