4.3L 807166A3 Water Shutter Replacement question/issue
kramerpage
I replaced my water shutters last night and I'm not happy with the results.
I sanded the interior area around the old shaft hole. Then cleaned with throttle cleaner and applied a thin coat of molly assembly lube.
My issue it that one of them doesn't always freely close. It gets hung up on its own hinge. So it closes 6 out of ten times. I removed it and sanded some more which did help slightly but that area is very clean now. It seems like its on a slight bind.
Is their a trick to this install? The tech sheet says to make sure the freely close. Do I remove more material?
I sure did like the older style better. The worked great, seem less restrictive and the operated super freely.
Thanks for any suggestions...
Ayuh,.... If water rushs up the pipe, they'll close,....
I think, yer over-thinkin' the situation,.....
kramerpage
Ok thanks. Lol. I will move on then. Thank you sir.
tpenfield
What Bondo said . . . also the shutters are not intended to be a water tight seal, rather provides a good blocking effect for water rushing up the exhaust tube.
kramerpage
Yes. I just thought for the money and the are genuine mercruiser parts they would at least function for their intended purpose. The mechanic at my marina warned me when I gave him my other donor Y pipe. He stated use the older style if possible but my grommets were worn and I couldn't find em new. Thanks for the insight.
