4.3GLPLKD started right up last week after taking it out of storage. Unhooked battery charger, covered it back up. Tried to start today, turns over great. Did the same procedure last week of pumping the throttle a few times, it's squirting gas into the carb, checked, pulled one of the spark plug wires off the plug and it shot a spark to the riser from 1/4 inch away from contact. Can't figure it out. Brand new spark plugs Distributor cap style ignition.
Suggestions?
Unhooked the kill switch and hooked it back up again. Nothing. No stumble, no cough, nothing. Ancedotal, maybe weak fuel squirts when the wife was pumping throttle, and increased cranking speed when throttle was wide open. Other than that, I got nothing. Hooked the charger back up. Don't have a fuel pressure guage, but wouldn't at least stumble if I'm seeing fuel go in the carb and seeing spark?
Thanks
Suggestions?
Thanks
