Re: 4.3 volvo Won't start
After viewing the above diagram in this thread posted by Don of the fuel relay compared to the relay in Don's post (picture below) about how to troubleshoot the engine starter system, I realized the relay I was looking at on the fuel pump bracket was not the right one. So I found it behind the black plastic box on the starboard riser. Took off the uppermost two screws and the lowest two screws. Got to it and here are the results with the test light.
A to good ground-produced a light
A jumpered with test light lead to D produced a light
C to good ground with switch on produced no light
A jumpered with test light lead to B and the fuel pump kicked on.
At least the fuel pump worked!
So tomorrow, if when jumpered with a test lead from A to B on the relay, the engine turns over, what next? I have no idea how to get to the neutral kill switch, or test from the keyed switch to the slave relay.
Again, all electronics work, and when the key is in the run position (off, run, start) the hour meter starts clicking. In the start position, nothing.
Thanks!
Thanks!
