4.3 Volvo penta won't start
charlie1900
Hi I have a 2006 Volvo penta with a rebuilt starter and a new battery but won't start only spinning of the bendict drive
Any help would be great
tlewis1
Does the bendix ever jump up and engage the flywheel? I would make sure the battery has a full charge and that all the wiring connections are clean and tight. Aside from that sounds like it may be a faulty rebuild. I have installed brand new starters out of the box and had them not work.....very frustrating
charlie1900
Can someone explain the circuit for start signal from ignition? Power route?
alldodge
This is a Merc but the sequence is the same. The run circuit is not here, just the start. Red is full time power, once key is turned to start the Yel/red happens
As tlewis mention above and I tried in your other thread, we both think you have a brand new starter problem.
