4.3 MPI
wolfdel
turn the key to on ecm cycles charges fuel system turn key to start and I think I hear a circuit breaker "click" no start and then dead, think it could be the connection battery feed to the starter connector to the starter.it resets not a easy thing to get at twins 27 formula pc
alldodge
Howdy
Need more info. You have twins yet this only happens with one or both motors?
What do you mean "not easy to reset"?
wolfdel
I meant not easy to get at starboard, flush system in the way I think it is the 90 amp breaker set on the starter
wolfdel
sorry port is fine starts runs, it is actually a fuse assembly part #79023A91
alldodge
Don't see a breaker resting by itself. There are thermal breakers but don't know of them being used on a Merc.
The part number listed is the 90 amp fuse, if it blows it needs to be replaced. If it blows the most probable cause is the alternator.
What is the flush system?
