4.3 mercruiser making oil
PDavis
I have a 1988 Chapparal with a 4.3MC alpha1.
indications are(may or may not be related) oil pressure runs about 60 at idle and 80+ above idle. about every 3-4 hrs the oil level creeps up about a qt on the dipstick. (no water or bubbles) most likely fuel. there is a slight fuel oder to the oil.
I was thinking a fuel pump diaphram but it runs great.
any thoughts?
Paul
180shabah
Re: 4.3 mercruiser making oil
Ruptured diaphram is a good possibility.
firehog6305
that would be my first thing to change or repair *fuel pump*
Coors
check the transparent tube funning from the fuel pump to the carb bowl.
If anything is in there, replace the pump, and change the oil.
poolmedic
Most certainly fuel pump-- same thing happened to me. Ran great until one day it died all together. I went to start it in the driveway before going out and nothing. Just make sure you use a marine fuel pump and not automotive.
Randy
