4.3 merc . spring starup
samurai1988
almost seemed motor seized after 4 or 5 try's
starter would not Engauge . replaced starter , did compression test ,
right bank all about 125
# 6 125 # 2 75 # 4 100
sprayed all cylinders with 4d 40 let sit
test #2 75 #4 zero all plugs out turned freely
#2 and # 4 added engine oil and let sit tested #2 125 # 4 zero
any ideas thoughts
thank u
Lou C
You can pull the valve covers and disable the ignition & just crank it over briefly (don’t want it to start will make a big mess) to observe of the valves open & close. But it seems like the heads are coming off.
Any water in the oil?
Possibilities:
Leaky manifold to elbow gasket let water drip down & corroded # 4 exhaust valve
Blown head gasket
The 125 results are low too normal on these is more like 150-165 psi.
flashback
On My old 350 I had a rocker arm stud come loose. In those days they were pressed into the head but I don't think they are anymore.
samurai1988
Possibilities:
Blown head gasket
no water in oil ... i think results are normal for this 4.3 at 125
but will check again on sites ... th u
Studs still pressed in
Normal compression numbers are 150 psi
