I have a 1996 (I think that?s the year) Regal 176 with a 4.3Gi. Recently I?ve had a couple issues and I?m searching for answers and wondering if the two problems are related, or just a coincindince that they are occuring simultaneously.
Problem #1 ? About 6 weeks ago I launched the boat and couldn?t get it started. I removed the air cleaner, sprayed some starting fluid and got the boat started. We stayed overnight on a houseboat and the next day I couldn?t get the boat started so I tried the starting fluid again but it didn?t work. I removed the fuel filter/water separator, dumped the contents, refilled with fresh fuel and it started up. We tend to boat every weekend and the problem is sporadic. Sometimes the boat starts right up, other times I can simply spray starting fluid but sometimes I have to remove the fuel filter. The problem has been getting worse each weekend and I really wanted to make it to Labor Day before beginning repairs. However, this Labor Day weekend was the worst so far and I had to remove the water separator multiple times. Note: I have gone through many tanks of gas pulling kids on wakeboards and tubes so I don?t think its water in the tank but who knows. I?m thinking more of a fuel pump or sensors. Any thoughts?
Problem #2 ? About 3 weeks ago the boat started running a little rough at idle. Black soot could be seen coming out of the outdrive and it gathered on the transom. Once the boat is put into gear and brought up to speed, it seems to run great but as soon as I bring it back down to idle the black soot can be seen again. Timing belt?
