4.3 firing order - this sequence looks wrong
ShoalSurvivor
BEFORE removing any wires, I traced them all, and this is what I found:
The numbers correspond to the FWD numbers on the distributor cap.
I would expect some symmetry, and this just seems off.
I replaced the plugs recently, and marked them, and this is also the only way the existing wires reach all the plugs.
Is this POSSIBLE?
I couldn't find a definitive diagram - is there one?
or do I need to pull the plugs to find the TDC, etc.?
222 HP Factory Remanufactured 4.3L
Specs: 225 HP @ 4800 RPM ‑ Standard / Left‑Hand Rotation ‑ Remaunfactured 4.3L Partially Dressed Marine Engine Assembly. Features Include: New 600 cfm 4bbl Carburetor, Electric Fuel Pump, Nodular Iron Crankshaft, Roller Camshaft, Vortec Cast Iron Cylinder Heads, Stainless Steel Valves, 9.4:1 Hypereutectic Pistons, Full Roller Rocker Arms and Thunderbolt V Ignition.
ShoalSurvivor
Upon further inspection, it IS possible that I switched the #2/#4 wires (there is sufficient length to reach either way), which would make the correct sequence:
Is this more likely?
Fun Times
To start, the numbering system in the first photo is off… 4 & 2 are swapped incorrectly… 2 is up front 4 in the middle.
