3M 5200 cure question
travish
Will 5200 cure in cold weather?
Low 40's - high mid 60's - next several days.
If it will cure, can If I use it tonight (Tuesday) and fiberglass (on Friday) (High 80 fri and sat) around the piece I am glueing down tonight and the 5200 still cure under the fiberglass?
Thanks
Travis
Woodonglass
Re: 3M 5200 cure question
This will tell you what you want to know. Basically 40 to 100 degrees application temp. 48 hrs for tack free and 7 to 14 days cure time.
Woodonglass
It requires air and moisture to cure. I would not cover it with fiberglass before it cures. IMO
travish
Thanks man, that is the info I needed right there.
Travis
