jdubslopro
Thread starter- Joined
- Mar 5, 2010
- 91
Hey guys I have a Mariah shabah 202 that I rebuilt my carbed v6 (raw water cooled) in due to water ingestion/bad bearings. The motor got water in it again right after the rebuild so I bought a freshwater cooled horizon 350 mpi and just rebuilt it. Now I need a little help finishing up.
First, there is a water port on top of the intake manifold (not the one where the water manifold/thermostat housing goes) that my original motor didn't have. I'm running my original water pump (the guy that sold me the motor kept the freshwater closed cooling system for his boat).
It also has a fuel cooler that I need to plumb into the system somehow, but I don't know the proper way to make it work with my setup. I'm thinking of taking the hose to the exhaust manifold and running it to the fuel cooler and then back to the manifold, as the hoses appear to be the same size.
Also, there is a vacuum line from the fuel pressure regulator that I'm not really sure where it goes...there's no vac ports on the I/m.
Finally, read somewhere on this forum about the shift interrupt switch (this motor came from a bravo drive) that I would have to wire to the ecu (white wire) to prevent drive damage while shifting. If someone could point me to exactly which wire that would be very helpful. Also any insight or advice to the first couple things would be great.
