flashback
- Jun 28, 2002
- 4,450
Did a lot of searching before I posted this, Its been a while since I've been here,,I had such good advise from folks about 5 years ago for my rebuild, that I had no need to come back, that and moving to a rural area with no affordable internet service pretty much took me out of the forum game, but here I am on a dial-up, and it's good to see a lot of the old faces...
Ok, to the point, 350 pre 86 block with 4 bolt main and stock heads. The #3 cylinder has about 35# comp, and a wet plug, no water in the cylinder or crankcase, All the other plugs look good, I have not run comp test on other cylinders but will do so tommorrow and will follow the instructions that I found here on this link http://www.boatfix.com/merc/Bullet/97/97_25.pdf
I figured most likely that it is an exhaust valve that is damaged but I don't hear any unusual noise which stumps me a bit. as in my limited experience with valves, they usually get noisy when they are damaged...
Anyway, I would appriciate any help you can throw my way and in the mean time I will do some further tests and see what I come up with .................Thanks..FB
