35 johnson outboard jumps in & out of gear
Status
Not open for further replies.
Daviet
Re: 35 johnson outboard jumps in & out of gear
Gear in top picture looks bad to me, where the dog has been jumping over.
Kevin 393
what about the shift craddel is it ok or is it in bad shape my johnson did that b4 and it was the shift craddel may want to check it out
Kevin 393
hi I dont know what you think of this but you should be able to flip the gears put the fw gear on the other side of the shaft and the reverse gear where the fw gear was and flip the clutch so it will be on the healthy side for foward you dont rev to high in reverse so it should be ok if the gears are reversable just a thought
Kevin 393
oh and the reason I say this is because I was able to do this with my 40 hp johnson good luck with the fix
Kevin 393
Hi are you still having the gear probs ? if you live in Ontario Canada let me know I'm sure I have a set of gears at my dads house for a 35 hp johnson I just found them last weekend I will check them out if you didnt get the prob fixed
rebranger
Look good to me, but then what do I know! Turn the dog around & see how it runs.
johnson79
I know this is an old thread but I wanted to offer some insight that I couldn't find online. That may help someone else. I was having the same problem and it got progressively worse, like it was the clutch dog. I opened the access cover to disconnect the shift linkage (previously pictured in this thread) for repairs. I found that the coupler you disconnect to drop the lower unit was loose. I readjusted and tightened it, now it's shifting and holding in gear better than it has since I've owned it. Save yourself some hassle and check this first.
GA_Boater
Welcome aboard.
Yes, this is an old thread and it should stay in bed. Read the Help Tip on top of the page. Starting a new thread is how we like this to be handled.
Closed.
Status
