35 hp to 50 hp engine swap
Westeed
have a 35 hp long shaft force '88. Picked up a 50 hp short shaft '89 for $200. it seemed like a decent deal. Though my transom is 20". I don't really want to buy a jack plate for $500. The motors themselves seem to be very similar the props/ lower unit gear case size/ motor cover. Obviously the engine is larger inside of the 50hp. I'm thinking I could pull the 50hp off of the ss and place it on the ls body... Is anyone familiar with these motors? Is there something else I should consider? My throttle and ignition are built into the boat (aluminum bass style boat) and I don't really want to remove them. I did receive a mountable throttle assemble with the 50 hp though. Havent checked it out for compression but the previous owner said there was spark and the flywheel on top turns. Should i invest in a jackplate or attempt to swap engines? Any Ideas? Much appreciated! Max speed currently 16mph with one person... 12mph with two people... Looking for a little more get up and go.
ebentraywick
Re: 35 hp to 50 hp engine swap
i whould try the 50hp in a test tank. before doing all of that work on a outboard that may run or not... check that out and get back2 me
Westeed
Figured that might be a good idea. The thottle cables are disconnected and some of the wiring as well. It's gonna take:redface some tinkering to get it tested first. Might take me some time. Be back in a little while. Going to build a stand for it right now to work on it. I'll take closer looks at the two also to see if the bolt paterns look the same. Thanks
ebentraywick
yeah just take your time dont rush it and all ways start it in water. even if u turning it over..
