turbo_bird
Thread starter- Joined
- Jun 3, 2016
- 5
Hello all, I've recently acquired an old Johnson Seahorse 35hp outboard that I've got running again. It was my grandpa's, and I'm looking forward to taking it out for a test run soon. The motor plate says it's an RD21, and the serial # is 277320. It's been sitting as long as I can remember, but it fired up without too much trouble after some fresh gas and plugs. I was wondering how old this thing is and if there's anything I should be careful with? I've never had a boat before, but I'm decent at keeping other stuff going. Here's couple pictures of the engine and the boat it goes with.
It should go pretty decent, the boat is only 13'6". I remember riding in it when I was a kid, but my grandpa didn't really open it up because he said it burned too much fuel. Inside the engine cover it says to mix it 50/1, so I'll give that a go. It's a bit richer than that because my gas can doesn't quite hold 6 gallons, but better a bit extra oil rather than not enough. I ran it a little bit today in the barrel, and it was spitting water out, so at least the pump seems to be working. I also put fresh oil in the leg and had to repair one of the sparkplug holes. Thanks in advance for any help or tips.
Kristian
Kristian
