35 HP Johnson age and other?
turbo_bird
Hello all, I've recently acquired an old Johnson Seahorse 35hp outboard that I've got running again. It was my grandpa's, and I'm looking forward to taking it out for a test run soon. The motor plate says it's an RD21, and the serial # is 277320. It's been sitting as long as I can remember, but it fired up without too much trouble after some fresh gas and plugs. I was wondering how old this thing is and if there's anything I should be careful with? I've never had a boat before, but I'm decent at keeping other stuff going. Here's couple pictures of the engine and the boat it goes with.
It should go pretty decent, the boat is only 13'6". I remember riding in it when I was a kid, but my grandpa didn't really open it up because he said it burned too much fuel. Inside the engine cover it says to mix it 50/1, so I'll give that a go. It's a bit richer than that because my gas can doesn't quite hold 6 gallons, but better a bit extra oil rather than not enough. I ran it a little bit today in the barrel, and it was spitting water out, so at least the pump seems to be working. I also put fresh oil in the leg and had to repair one of the sparkplug holes. Thanks in advance for any help or tips.
Kristian
jbcurt00
Get a new impeller, its out lasted its intended service life, by a lot...... in fact getting a complete water pump kit would be prudent.
Its an 1959 RD-21.
Napa can get (or may have on hand) lots of wear/maintenance items for vintage Johnsons.
Get a parts manual and a service manual.
Many of the OEM part # have been superceded, often multiple times, so having the OEM # and researching the parts you need online will get you the current part #s pretty easily.
Iboats carries many of the parts for my 1970 9.5hp Evinrude so be sure to check here for parts too. Forum members get a discount, so be sure to ask about it.
Welcome to iboats
Its great to see/hear its staying in your family. Wish I had my grandfathers fishing boat and his Dodge Charger.
jimmbo
I would really like to see where in the engine cover it says to use 50:1, that engine was 5 yrs old when Johnson switched from 24:1 to 50:1. But because it has all the roller/ball/needle bearing required, it can use 50:1
If you are planning on running the engine in a barrel, the water needs to be 3 of 4 inches higher than the 'Super Quiet' decal in order for the water pump to prime.
The cowl was unique on those engines, you were able to change the spark plugs with having to remove the cowl. There was a hatch on the back of the cowl you could open or remove and there were the spark plugs.
Find some way to secure the bow of the boat when it's on the trailer. That trailer has no bow stop
lindy46
Yeah, run that motor 24:1 and get a new impeller. The old one may break up at any minute and strand you on the lake if you notice it's not pumping, or burn up the motor if you don't notice that it's not pumping. When it breaks up, it could also clog the cooling lines.
turbo_bird
Oops, you're right, it's 24/1. I mixed according to the engine decal, but the 50/1 on the tank decal is what stuck in my mind. I'm in Canada and used to metric units, and it's been ages since I've mixed gas for a two-stroke. I thought the spark plug access ports were a nice touch too.
I had the barrel jacked up so it was almost touching the bottom of the fin on the leg and it was right full when I ran it. Probably still questionable on the level. I just wanted to make sure it would actually start before heading to a lake. As for the trailer, I never thought of a bow stop. The way the trailer is now is how this boat was always hauled, as far as I know. Thanks again for all the advice.
Kristian
HighTrim
That is great that you are keeping Grandpa's boat! Fantastic. Should push you along nicely. Where abouts in the great white north are you?
turbo_bird
I'm in BC, near Kamloops. I had a look at your website and will keep it bookmarked just in case I need anything I can't find locally. I just got my boat license online today (government money grab) and we're planning on a test run tomorrow. Hopefully it goes well. I don't think the engine has been run a whole lot, my grandpa got the boat and motor in the 80's, and never really used the motor because it burned too much fuel. He mostly used it with I think either a 5 or 9.8 outboard.
Kristian
jimmbo
Kristian
Metric is easy, the tank is 5 gallons which is 22.7 liters. so just dump one liter of oil per tank of gas and you'll be close enough.
turbo_bird
Yup, I just had a brain fart and the 50/1 marked on the tank stuck in my head. All straightened out now. I'm hoping to take it out for a quick test run this afternoon. I haven't done anything with the water pump, so hopefully it holds together. I'll be keeping a close eye on it for sure. I don't think this motor has been run much at all, at least not since my grandpa bought it in the 80's. He bought it from some friends that I don't think used it much either. A bit of a refresh could be a good winter project though. I checked boat info.com, and it looks like a defunct website. Does anyone have any other sources for a service manual for these things? I haven't had much luck with Google, but then I suck at finding stuff on the internet anyways.
Kristian
thomas15
If it were my boat, in addition to the advice already given (change water pump pronto), I would also replace all of the fuel lines, from the gas tank to the carbs. I would also rebuild the carbs. Drain and replace the gear oil in the lower unit. Do a compression check and record readings for future reference. Purchase and carry on-board an extra sheer pin for the prop.
Keep in mind, as a new boater, that if you run out of gas on the water it makes for a long day. So make sure you keep track of where you are and how much fuel you have.
turbo_bird
Thanks for the link jimmbo, very useful. I'll have to see if I can get my compression release working again.
Good advice, thanks thomas15. I did cahnge the oil in the leg before taking it out, as well as checked all the fuel lines and cleaned out the fuel filter and glass bowl. Next time im in town I'll remember to pick up a shear pin. And I'll try to track down parts for the water pump. A compression test sounds like a good idea too. My uncle said he and my grandpa did the carbs and drained them not too many years ago, so I hopefully won't have any issues there. I took it out today for a bit of a trial run, and it ran great. With just me in the boat it will do 25 mph, with the wife and kids it will do 23, according to the GPS on my phone. We were on a fairly small lake, but I still made sure to have extra gas on board, just in case.
And here's a video of it. I don't know how to embed a video, so just a link.
https://youtu.be/qriQexDwC6g
Kristian
jimmbo
Your carb has adjustable Hi and Lo speed mixture adjustments.
geoffwga1
Do not procrastinate,replace the impeller at least if not the rest of the water pump.You have a lovely old motor there which will last for many years with proper care.Also strip and rebuild the carb,the kit is available right here at Iboats I'm sure and it does not cost much,it's pretty easy to do and help is available here if you need it.Might also be a good idea to pull the flywheel and have a look at the coils and clean and regap the points,also pretty easy.
thomas15
The reason I mentioned changing the fuel lines is that ethanol eats up the older fuel lines. So they may not be leaking but inside they could be starting to come apart and little bits of fuel line in the carbs are not good. Unless of course you are using ethanol free gasoline. Also fuel treatment for ethanol is cheap insurance against future fuel issues.
To giver you an example, ethanol ate up the fuel lines on my 2001 Mercury outboard so I had to replace everything including the hose and squeeze bulb. If you have a replaceable fuel filter just replace it.
I really like your rig, looks retro and I imagine it would be a blast to drive.
