rhysdejager
- Nov 17, 2008
- 3
i just bought this engine
reverse works fine
fwd is like it isnt there
the very first time i put it in fwd it went for about 2 seconds then came out.
so while the engine was off
i put the the engine in reverse (manually with the leaver on the side of the engine) and spin the prop, it doesnt spin and you can feel the compression of the motor
i slowly move the gear changing leaver to the neutral position, its points straight up and down but the prop wont spin freely (its still in reverse)
i move it half way between fwd and neutral and about in the middle there it comes out of reverse, you feel the prop will spin freely
you push the leaver hard fwd to the fwd position and the prob spins freely
as if its in neutral
i know its bad to change gears slowly while its running
however the engine wasnt running at the time
a friend told me it could be the dog clutch
but when the leaver is pushed hard fwd the prop spins and you cant feel it touch any teeth at all
cheers
reverse works fine
cheers
