ssmith1120
Thread starter- Joined
- Sep 5, 2007
- 5
HI, I have a friend that has a boat that we have been working on for the last few months and we are stuck right now. The first thing he had repaired was the pumps because they were not working. Now this year the engine had trouble starting. We changed out the spark plugs and played around with the carb to get it set right. We followed the steps in the manual. Now we were using a boot with a water hose hooked up and we had water coming out of the pumps and everything was working great. That weekend he took it out and it started right up and it ran great for a while. He turned it off fished for a little while and it would not fire again. Last night we filled up a trash can and put the outboard in to to see what is going on. It started up ran at idle for a while. Then we ran it to get is warm turned it of and it would not fire again. You can hear the engine spinning but not starting. It is turning over but not firing.
We heard water leaking and we found on the GEARCASE on the right side on the back screw there is a hole right next to it. We also saw light brown oil/greese with water mixture coming out when we lifted the outboard out of the water.
Is this a problem or is it our problem. I am wondering if water is getting into the engine and not letting it create a spark to start. Again when we had the boot on it a few weeks earlier it did not have a problem starting it. Only when it is in the lake or water.
I am sorry this is so long but do you have any suggestions or ideas on what we can try next? Do we need to replace the GEARCASE or can we take it off and put a weld on the hole?
He is about ready to throw in the towel and I think that we are closed to getting this working so any help would be appreciated.
Thank you for your time.
