302 Ford Leaks Oil
Gcompo
We have a 1977 Viking with a Merc 888-Ford 302. The bilge water is very oily. When I check the dipstick, it doesnt show any oil a couple times. If you bring the level back up is wont hold that level. It definitely has a oil leak from someplace. Looking for a suggestion where the leak might be on the engine??
I checked the oil filter and its not leaking. We use Mobil 1 in it. Could this be part of the problem? thanks for any help.
zbnutcase
Re: 302 Ford Leaks Oil
Could be the Intake manifold end seals, rear main seal, or even a pinhole in the pan itself from rust 'nutcase
Ayuh,... Only way to find it is get right in there,+ Look....
Bifflefan
Clean off the motor and then look for the leak.
When you find it, fix it.
