302 Compression check..not good. What?s next?
Fatbs
Port side starting at the front
150
145
55
75
Starboard side starting at front
150
155
60
55
Total rebuild??
Pull manifolds and inspect. I am betting they are at end of service life. I am also willing to bet the valves are rusty. You may get by with new risers and manifolds and rebuilding the heads
Ayuh,.... Or a new/ rebuilt long block,.....
Fatbs
kind of new at this.
Exhaut manifolds? tis so i know the port side is cracked for sure.
Is this a new to you boat?
Cracked exhaust manifolds are a sign of improper winterization.
Be for even buying manifolds, pressure check the block and heads. You may be looking for a complete new bobtail
harleyman1975
Ensign
And as much as I liked my old 888 it would be now that you would update to a more modern driveline with a chevy and an alpha 1 gen II from another boat. Much easier to get parts for.
