I bought a used 1995 Mariner 30 HP and when I took it out on it's maiden voyage it ran great for about 10 minutes then died. Upon further investigation the idle needle and the idle speed screw were both missing from the carburetor. I found the idle needle with spring laying in the motor housing but the idle speed screw is nowhere to be found.
The carburetor model is a WME 3301 824854 C1. I replaced the idle needle and the motor will at least fire now but will not stay running long (10 secs). I will replace the idle speed screw but what I am wondering is what type of adjustment is required for this screw?
Thanks,
Scott
Thanks,
Scott
