3 prong female fuel fitting
evinrude enthusiast 93
does anyone know where to get a 3 prong female fuel fitting? ​mine has broken and I looked on e bay amazon craigslist napa advanced I boats outfitting stores I cant find them new or used anywhere.??
flyingscott
Try the AOMCI website or look for another tank they usually have the hose and fittings connected to them.
its not the tank I have new and old tanks both connections but most all my motors have the 3 prong male end they are all antique evinrudes but 2 so in the case I change to 2 prong I will have to change all my motors with conversion
3- prong male or 3-prong female your post #1 conflicts with post #3
F_R
By "3-prong", I assume you mean it is for the twin hose pressure tank. the hose-end connector is part number 375587, no longer available from OMC/BRP. You wouldn't have wanted to buy one anyway, the last ones were priced at $149.00. There are plenty of used ones out there for less than $50. Post a free wanted ad on www.aomci.org Webvertize ads pages.
Vic.S
Are you looking for the dual hose end connector ( engine end) for use with pressurised tank systems. If so ITYWF it is part # 0375587 and that is is now obsolete and unavailable.
There are folks who have a bunch of these.---As stated look around at the -----AOMCI----Should be no problem at all.
SD; ​all my motors have the 3 prong (two hose and one clamp prong) but the piece I'm in need of is the opposite female piece that belongs to the fuel line.
I was saying I have the other one line tank with bulb and 2 prong female piece but most my engines don't have that fitting.
vic; yes that is what I need and yes ik they are obsolete all u can find is single hose 2 prong now adays that's why I am looking for used bc ik there still out there iv seen them before.
RR and FR; I have posted an add thank u for the direction to this antique motor site I appreciate it.
if you have a pressure tank setup (2 lines), you should not have a bulb.
my pressure tank has 2 lines no bulb with 3 prong female fitting which is now broken
my regular non pressure plastic tank for newer motors with 2 prong does have a bulb
I do properly understand fuel line setups for each type. all I'm in need of is a 3 prong fitting female
HighTrim
Got your message. I have a bunch I have rebuilt with new o rings and springs and painted. I use F_R's tool for this. If he still sells them, I recommend you all buy one1 lol
Makes the job simple and easy.
