3.ol merc engine dripping water
lewski
Hey everyone, just bought a 2000 bayliner with the 3.0l mercruiser. I have a little drip of water coming from the front of the engine when its running. Is it the water pump. Do I need to replace the whole pump or just a gasket or seal...Thanks
Re: 3.ol merc engine dripping water
Ayuh,.... Exactly where is it leakin',..??
fishrdan
^^^ yup, where's it leaking, exactly?
The water pump has a weep hole, so that could be your issue. Remove the pulley and see if there are traces of dried up water coming from the weep hole. If the pump is leaking, it needs to be replaced.
Renken89
What exactly does "dried up water" look like lol
fishrdan
OK then, rust stains, drip marks or calcium deposits...........
Sheesh :facepalm:
Here's a pic for ya'
tank1949
And, if you don't act fast enough, water may compromise crankshaft seal causing harmonic balancer to rust or pit seal.
