3 battery charging problem
justick
All,
I have a 3 battery system in my boat. 1 starting battery that is wired to the engine. And 2 12v batteries that are wired as a 24v system to run my trolling motor. I have a 3 battery charging system installed with 3 leads to the to batteries.
Now here is the problem. I don't think the trolling motor batteries are being charged. Since the system is wired as a 24v system and the battery charger is a 3 battery 12v charging system I don't think the trolling batteries are getting charged. There is a red light on constantly when I look as the battery charger. The starting battery eventually charges and I get a green light from the charger but the two batteries (24v) system stay red. I think I need to add a battery switch to separate the 24v system into 2 12v systems? Can someone let me know if my thought process is correct and what kind of switch would they recommend. I would like to mount the switch on the outside of the boat next to the charging receptacle since the batteries are kind of hard to get to.
Thanks
John
lowell7963
Re: 3 battery charging problem
Justick, I'm not sure what a 3 battery charger is, but if you could add a wiring diagram, even hand drawn it would be great. A Perko Battery Selector switch would maybe work. Lot's of them on Ebay.
Look into this thread if you haven't yet. Lot's of discussions and ideas about batteries.
http://forums.iboats.com/showthread.php?t=224004
