3.5 nissan outboard
albie
just rebuilt carb, ran great at home, took it out and it runs fine on idle, give it a little throttle and it surges and then shuts off.
tank , fuel lines and filter are clean, has new plug
any suggestions?
pvanv
Re: 3.5 nissan outboard
What is your model? What method did you use to clean the carb?
pvanv
Is this an NS3.5A 2-stroke, or an NSF3.5A 4-stroke?
Spray carb cleaner is inadequate, a 4-hour soak in real carb dip is necessary if the carb is too lean due to varnishing.
albie
its a ns3.5 2 stroke
carb is spotless, i dont understand, it ran like a charm when i tested at home
Sea Rider
Assume by filter clean you mean fuel **** inside filter, right ? There's a small black oring inside intake manifold that seals against carb nozzle, is it seated ? If dried, hardened, worn, place a new one. You must always test under load & speed, at home, at idle inside barrel it's a different story.
Happy Boating
