FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
My 2008 Tohatsu 3.5 four stroke outboard (MFS3.5) stalls if let run on very slow idle.What can I do to stop this. The plug is new, carb slow idle jet was removed and cleaned.
Did you do a complete disassembly and 4-hour soak in real carb dip, such as Tyme, followed by a warm water wash-out and a good blow out (either with compressed air or carb spray)? If not, you probably still have varnishing in the low-speed circuit. Especially since you found junk in the main jet. After you are 100% sure that you have really done a very thorough job on the carb, reassemble everything, and then adjust the warm idle per the specs in the Factory service manual, using a good shop tach. If you still can't achieve a slow enough idle, and everything else (including the spark plug) is in perfect condition, the carb may to be replaced.
