hi salenity
Thread starter- Joined
- Aug 1, 2007
- 52
Hi, I just got a 3.5 Eska and it will start but barely run. My first thought was carb... but after cleaning the bowl and checking the needle & seat it still has problems.
So I pull the plug and check the spark. I don't think it's firing every time it should more like fire twice and miss then fire again. it is not a rhythmic pop,pop,pop as it fires more a pop,pop---------- pop,------- pop,pop... So I decided to test the spark with my spark gap tester, If I remember correctly my 200hp will throw a spark 10mm this one will barely throw a spark wider than the gap of a spark plug.
It is a Magneto with Points. I looked and the points don't look old and the gap on the points LOOKS good
HELP?
HELP?
