fngboater
Thread starter- Joined
- Jun 9, 2011
- 181
I just finished rebuilding my motor and put it in the boat. It started right away no problem after installing the distributor. I hooked up the timing light, put the dist in base mode by jumping the two white wires together and bypassing the shift interupt switch by hooking the two wires together. I was able to set the timing to 1* btc. it idled and reved pretty darn (i could tell it needed some advance as i reved it ).so i turned it off and removed the dist jumper wire . my problem is after taking it out of base time mode it didnt want to start. anyone ever had this problem? put the jumper wire back on and it fires right up and reves and idles darn good. is it advancing to much without the jumper wire connected? does the dist have a mechanical advance also? can my timing light be giving me problems? there is no advance knob on the gun so i know its not that.
motor is a 96 3.0lx mercruiser with est ignition firing order is correct 1342 and so is the rotation of the dist
