3.0LX GM alternator belt tip
KevinKay
I used a Dayton V belt from Granger, part # 4L400. It is a little wider so It sits a little higher and tigher-had to finagle and stretch it a little to get it inbetween the mount and on the pully, but works perfect. Cost $5.91 as assposed to the Mercrusier part costing $26.
I did not jack the engine, I loosened both bolts, removed the top one, tipped the spacer forward, put back the top bolt, removed the bottom and spacer (and again to get the belt-in and out). I did not feel any engine shift and it was not a time saver as slipping the jack under would have been eaiser in the long run.........but might be an alternitave it your out on the water.
just thought I would share as I get alot from here
saaabe
Re: 3.0LX GM alternator belt tip
have you had any problem with the belt before I have a 2007 3.0L mercruiser and the drive belt the same as your has broke two time and now the second time it looks like I blown the engine
