3.0L cobra vs 2.3L cobra
agwa2111
I had my 1988 3.0L Cobra outdrive replaced. It had no reverse.
The mech replaced upper & lower with used cause he had one at the shop.
I's the gear ratio the same on the 3.0L and the 2.3L? How can I tell which one he put on? Ser #?
The reason I ask is the boat would do 40 mph before now all I get is 24. The only thing that is different is the out drive.
I get 4600 rpm just 24 mph.
Re: 3.0L cobra vs 2.3L cobra
Ayuh,... What about the Prop,..?? What pitch is it,..??
Don S
The the 87 -90 2.3's had a 2.00:1 gear ratio, the 3.0's had a 1.71:1 ratio.
in 86, both were 1.71.
Did you get 4600 rpm before.
LilRedNeckGirl
somewhere on here, there is a sir # guide to determine whats hangin on the engine pushin you around. sounds like prop to me. check size & pitch. 4600 rpm. That would prompt me to look at the MFG specafacations to see what the RECOMENDED max RPM is. I run a 3.0 and seems my manuel says something around 4200 as max rpm, and that cruising should be around 3000 rpm.
Im thinking if your not at a comfortable cruise, up on plane and livin the good life at 3000 rpm's, something needs fixing... Remember, its a 4 cyl marine engine, not a weed whacker.
agwa2111
I've tried a 13 , 15, 17 with mixed results. 13 made rpms run high and less mph 17 more top end and less rpm. Yes I was running 4600 rpm with 15 pitch prop before I had the drive changed.
Ayuh,... Ya did leave the trailer in the parkin' lot, Right,..??
It sounds like there's Something else goin' on...
agwa2111
agwa2111
Yes there is something gonnin on. I'm thinking he put a 2.3 cobra on instead of 3.0. Not sure how the 2.0:1 ratio would effect performnce.
agwa2111
Sorry for the double post hit button twice
Ayuh,... A 17" or 19" Should give you about the Same performance as it had before,...
IF it's the lower gear ratio...
agwa2111
I guess the only way to truely find out which drive
I have is to take it apart and look. thx for the responses
tschmidty
Or mark the prop and turn the engine over one revolution and see how much the prop moves!
24 MPH, 4600 RPM is way too little prop or a gear ration that is significantly off. 13 15 17 are all relatively small props especially if the ratio is a 2.0:1 with a 3.0
agwa2111
Update Just took the plate off the top off out drive and counted the gears. The top gear had 23 splinds. I thought the 3.0L had 21 splines.
Did I mention the out drive came off of a pontoon boat that had 3.0L OMC.
