mickyryan
- Apr 18, 2016
- 4,214
1 remove outdrive as bondo posted above ,
2 remove unplug socke t/ wires and make sure no wires grounding bonding wires ect are still connected to engine starter will have red wire going to it from battery.
3 remove fuel line and plug with something that will seal fumes wirenut dowel ect
that will seal the fumes
4. unbolt the front motormount from the floor 1 bolt each side
unbolt the two bolts on the transom plate holding the engine bellhousing to plate
5 remove engine.
5 remove engine.
