3.0 tks seized - ran with no oil
mickyryan
1 remove outdrive as bondo posted above ,
2 remove unplug socke t/ wires and make sure no wires grounding bonding wires ect are still connected to engine starter will have red wire going to it from battery.
3 remove fuel line and plug with something that will seal fumes wirenut dowel ect
that will seal the fumes
4. unbolt the front motormount from the floor 1 bolt each side
unbolt the two bolts on the transom plate holding the engine bellhousing to plate
5 remove engine.
  • Like
Reactions: vak
vak
Do I have to drain lower unit oil before removing the sterndrive?
Found the trim rams...
Grub54891
Nope. It can be drained later, I drain it and pressure check it before removing it, as I have no stand at home to put it on. If I have it at work it gets the stand and can be checked over at any time.
mickyryan
while you have lower unit removed replace the trim sensors the water pump impeller and other parts that show wear check pins and when you are putting it back together remember plastic shims and spacers and for the love of god the big cotter key in the bottom and of course all of the stainless wires for the bonding . definitely get the manuals and watch them closely
vak
Does anyone have a recommendation about where to get a service manual? It's 2007 3.0 tsk alpha (carbureted). The boat is 2007 searay 175 sport.
Ayuh,..... Follow the links in Don'S Adults Only section, found at the top of the I/O forums, or in my signature,....
  • Like
Reactions: vak
vak
No Title
I removed the filter. There was some oil in it, I did not notice any obvious problems. What is the best way to cut it open? Hacksaw?
vak
I made some progress...
vak
Looks like I need a new gasket. What are good places to buy them? IMG_3412.JPG
vak
It snowed today...
Tomorrow, I'm pulling the boat out of the garage and removing engine anyway!
Any last words of wisdom before I screw anything up?
So far I understood that I need to disconnect all the wires and the fuel line. Then pull the engine. I have 1000lb rated ratchet tiedowns. Would they be good enough to connect the hoist to the gantry and the hoist to the engine?
The engine opening looks painfully small...
Grub54891
Tiedowns are not a good thing to lift with, they are designed for holding down an object, not lifting. I'd at least get a come along for pulling the motor, and at that, a come along is for moving a load, horizontally across. Not really meant for lifting, but still safer than a strap. Remember be safe!
mickyryan
get you a electric winch 65 bucks at Walmart able to stand 1200 lbs , then use a chain adjusting it from about 1.4 way back from front eye to back so you are pulling up on front and out , you might have to move boat back first to clear box then forward to get the engine out
