Steve Chasteen
Thread starter- Joined
- Sep 2, 2021
- 5
I have a 2015 175 Bayliner with Mercruiser 3.0. It will run just As it should, but an hour in it will lose power at high speed. Runs well at idle and low speed. Replaced the fuel pump, drained the Tank through the supply line to engine. This convinced me that the tank had no water, the check valve was working and the line filter was not clogged. What else should I look at before I got into the cab. It has the TDK? Carb! Runs great and then goes down hill fast. Still runs but no real power. All help is appreciated!
