3.0 mercrusier oil leak
firedude204
I've got a 2003 3.0 mercruiser that's got an oil leak around the fitting i have circled. needing info on the name of that part and what that tube is? should i replace the whole tube or just the fitting? the picture i s just for referencemercruiser-3.0-slika-66179113.jpg
Scott06
Thats the fuel line coming off the fuel pump . You say it is an oil leak? That is a flare fitting for the pressure side of fuel pump. Would just try snugging it up.
if it is oil not gas would think you have oil leaking out from where pump attaches to the block or the diaphragm in the pump as there will be some oil on top of the upper diaphragm in the pump
would make sure there is no fuel in the yellowish tygon 1/4” tube coming off the fuel pump up to carb
firedude204
thats what i thought it was but seeping out of the top of that flare fitting is an oil like fluid. just wanted to make sure i wasnt missing something. i have to do some inspecting that its not coming from somewhere else.
Scott06
you can try snugging it up see if it goes away. instead of replacing one of the carb shops i buy parts from sells these copper flare washers like these
been amazed at how easy they seal up older flare fittings
firedude204
i took it apart and noticed a rubber plug like gasket inside the nut that looked a little worn. i cleaned it all up and snugged it all back together. seemed to make it worse. ill try what you posted and see how that does.
dubs283
Its a flare fitting, as mentioned, but does not (if appropriate) require an o ring. The fitting normally seats when the brass trunion is torqued accordingly.
The flared portion of the fuel line seats to the intake fitting of the carburetor when the hex style fitting/trunion is torqed accordingly.....
Edited for, " repeat much?"
And I don't mean that in a passive aggressive way, this is the internet after all
