3.0 L choke
mavryk
I have a 1988 3.0L OMC with 2bbl hot air choke carb. The choke body is loose where it attaches to the side of the carb, causing a vacuum leak. It appears there are two screws that hold it against the carb. Are these behind the side cover that is used to adjust the choke? Can anyone point me to a diagram of the carb to showing how to dissassemble? What is the proper way to adjust the choke?
Thanks
