3.0 hard starting when cold
Rderr12
Re: 3.0 hard starting when cold
Yes.. The esa module.. And the spark plugs are black and wet from fuel
Rderr12
How do you know when the engine is supposed to spark at the right time?
Rderr12
Boomyal
That's a good indication that the engine is flooded. Clean them then dry them off with brakekleen or ether. then reinstall them and try it now that you got your choke adjusted.
You know when everything is getting spark when it should when the engine is properly timed AND the plug wires are hooked up correctly.
Rderr12
Ok I think I need new wires or something because I'm only getting spark to one plug
Boomyal
Well that would certainly be a deal killer.....however, to be sure it is the wires, move that one wire to a different cylinder on the distributor cap to make sure it will spark a plug from there. That would fairly well confirm your theory.
