3.0 GS Low Compression #3
TX Anthony
1997 3.0 GS Volvo on 24' Harris Pontoon. I have 30lbs compression on piston #3. Had a valve job done because it needed and thought that would solve the problem, it didn't. The shop is going to do the oil test to see if it is a piston problem. The cylinder walls look ok, wouldn't there be signs of damage if a ring broke? Could it be a stuck ring? I am planning on selling this boat and don't want to have to put a new engine in. Had cooling issue and engine did get hot. Any suggestions or insight would be greatly appreciated.
Re: 3.0 GS Low Compression #3
Ayuh,... Welcome Aboard,... at 30 psi, the rings must be completely Gone,....
Have ya done a leak-down test to see where it's goin',..??
bruceb58
Th cylinder leak down test will tell you if its valves(and if its exhaust or intake) or rings. There is a chance you could have a leak to an oil passage would give you the same indication as bad rings would indicate however.
TX Anthony
An oil passage would be a problem with the head?
jerryjerry05
Do this quick.Pour a little oil in the piston.
Then do a compession test.
Then if the comp goes up there is a ring problem.
No change? The valve job didn't work.
The rocker arms opening and closing the valves like they should.
TX Anthony
Thanks everyone.
If it is the rings, should i just do a ring job, just fix this one piston or get a shortblock replacement? I bought a runabout and will be selling this pontoon so I am looking for the most economical option. I will post once the oil test has been done!
bruceb58
Head gasket. Not very likely but I figured I should mention it if you do a cylinder leak down test.
Do the test Jerry suggested as well.
Replacing the rings requires the engine to come out. At that point, might as well get a shortblock.
