Rmcduffie49
Thread starter- Joined
- Jun 5, 2016
- 14
I've tried but to be honest from what I can see it's coming from the area of that lower vent hole under the spinning driveshaft (only leaks when running). So it's either that lower vent hole or the top of the exhaust tube where it makes the u at the top. With that being said its just odd to me that with both of those being the area it's coming from why it wouldn't leak at all with the motor not running. It's a steady stream like barely turning on a faucet when the motor is running and absolutely nothing when the motor is off. I would also think that if it was coming from behind the motor it would be splashed by the driveshaft somewhat or dripping some before it gets to the back of the shaft and it's not at all. Bone dry above the spinning shaft.
