MadMick
Thread starter- Joined
- Jul 29, 2012
- 23
I AM NEW TO VOLVO OD’s and ENGINES
Parker with a 1996 290 DP with 2017 5.0 GXi
Issue: OD will trim up and down but will not trim up to trailer/beach height
Boat has trim gauge on dash. Also have what I believe is a trim control box (857534) behind the dash. It has a red light and I think an adjusting knob.
The guage moves up and down and is peggs out on either full up/down positions. I push the red button with the up button which I believe is to override and raise the trim into trailer / beach position and it will not raise further. The red light on the control box is red all the time.
I have with help determined that the issues is behind the dash. The relays and everything from there to the dash has checked out.
I did install a new Trim Sensor/Sender Gear Segment Ratchet on the Upper Unit helmet and I believe I linesit up correctly as per the knotch.
Having said all all this I may have messed up and the work and missed determining what the issue may be.
Any guidance would be most appreciated..
