28hp Johnson wont achieve full throttle
brinkkl91279
I have an old, 1960's, RX10 28hp Johnson I inherited with a boat. I have the engine running pretty good but it doesn't seem to want to come up to full throttle. If I push the throttle all the way up, the butterfly in the carb is only about half way open. If I am standing behind the boat on the left side of the engine there is a lever that goes into the mount plate and it is stamped slow, start, and fast. I am sure you know what I am seeing. With the boat throttle linkage disconnected and manually moving the lever, it stops in the start position. If I push and hold the lever it will move maybe a half inch past "start" but snaps back as soon as I let it go. Is there another adjustment I am missing. There is a barrel on a rod I can adjust but that puts the carb into the start position. I did replace the ignition coils, maybe I put something back wrong. I am quite mechanically inclined, just not so much with outboards.
flyingscott
It might have a throttle stop on it that only allows the throttle to partially open in neutral. With the motor off put it in gear and see if you have full throttle then. Don't worry about what the plate says they are usually not that accurate.
