280 outdrive upper gear case installation..
tim24
replaced bearings in flywheel cover /bellhousing. Replaced transom mount due to extreme corrosion. lower unit is now on and we are trying to align the upper stern drive unit with no luck we have tried just about everything and we just cant get it into place or get it to go into the holes.. We have already tried to raise and lower the tilt and it makes no difference almost like the upper unit is not in the right place or is too far back any help would be appreciated thank you.
