duckhunter55
Thread starter- Joined
- Oct 13, 2007
- 94
Have 1978 25hp johnson. After trying to do a lynch and sync, the motor will only idle now with a full choke. I will idle just fine with full choke but as soon as you push it in the motor starts sneeze pretty hard and then will cut off. At full throttle can run with choke off but not at idle. i have the low speed idle set at 1 1/4 turns. Could it have something to do with the idle screw on the side of motor? I have turned all different ways and was wondering where it should be set.
