I have 2000 year 25hp Johnson that i bought last summer with idle problem. I tried it last year on the water and it wouldn't run at all. It stayed on idle about 10 sec and then it sneezed hard. Checked the plugs (QL77JC4), upper was white and wet, lower black and wet. Spark jumps 7/16 as it should. Head gasket, exhaust cover gasket and left side cover gasket? (where fuel pump is mounted) are new. I sanded the head and exhaust cover+baffle so that they are flat. I think that the head was warped a little. Carb is rebuild. Link n' sync is okay. Now it runs pretty fine with muffs on but oily slime comes out from exhaust and plugs are just like before. Idle mix screw is out only about a half turn. I tried 1.5 turns and 2.5 turns out but almost stalled and smoked like hell.
Running but not perfect...
Any ideas?
Any ideas?
