roscottjr
Thread starter- Joined
- Jun 10, 2006
- 330
I am resealing the lower unit on my 1988 Force 125 but have run into a slight situation. In the manual it specificaly states with a warning that the gear housing cover is bonded with rtv sealant, however, it says nothing about using rtv sealant when reassembling. I know this has O-rings already but should I use the rtv sealant to bond it to the case as it was before?
Also, my gearcase seal kit I got for this motor has all round O-rings. I have doublechecked to be sure I have the correct set and I do. However, 1 of the O-rings for the gearcase cover is oblong shaped and not round. Do they not make the oblong shaped ring and this round ring works fine?
Robert
Robert
