Re: 25hp Johnson lower unit problems
Depending on the year, there should be a little oval shaped cover about halfway up the leg and thats where the shifter disconnect is, or if it is a later model the disconnect will be behind the water intake grates on the lower itself. I think that's probably what is holding you up.
