25HP '93 Johnson, lean sneeze---VIDEO---
Status
Not open for further replies.
oldboat1
You found low compression, didn't you? Think you should see something around 120 lbs.
1 3/4 out is the correct initial setting for the idle needle. Adjustment for a richer setting is 1/12 rotation c.clockwise, letting the motor catch up between adjustments. On the boat is best. In a test barrel is second best. On muffs is a waste of time.
Spark measurement is done with an open air tester, not the inline type.
BTW, is the nozzle gasket in place?
flyingscott
Do.you have a 3/8" gap on the throttle rod under the flywheel. What is. your compression
werewolf30
I just did a 15 hp 93 model that was doing that and found head gasket seeping water in cylinder causing a miss fire when hot
Status
