250 ficht ram injection 2001
seebar
hi.......wondering about problems that may arise if injectors are switched from different cylinders or used injectors from same model & year are installed..........cheers seebar
tashasdaddy
Re: 250 ficht ram injection 2001
not many of us know much about the Ficht.
jonesg
generally with injectors, replace the seals if you disturb them.
noelm
I do believe that the Injectors need to be calibrated via the correct software for your Motor, it is not even advisable to swap injectors from one cyclinder to another on the same Motor.
