25 evinrude
nighttrain
I have a 25 hp Evinrude I believe to be a 1996 that doesnt run right after a fairly hard hit to the lowerunit at wot,very little prop damage and no visible case damage.it was a floating log by the way.motor had slight vibration after hit i attributed that to the slight bend in blade of prop but after about 6 hours(parked at camp) i headed for home and it dropped to about half power after 10 minutes or so.did comp check at home top cyl.= 90 center cyl.=115 bottom cyl.=85psi. removed head to check cyl. no apparent gouging or scoring and very little carbon.good cross hatching. any ideas? what are the 1/8 holes in each cyl. wall above the exhaust port? sorry for the length of this post. model #E25TKLEDC serial#G04107902
yellow bird
Re: 25 evinrude
hello nightrain, my name is ed, I saw your name, and I am wondering if you are the same night train that I was in the navy at imperial beach california in 1952?? it was a class a school. at the time I was from Brooklyn NY, and i see that you are also from New York, so hence i thought that you might be the one I am looking for. You can send me a message at, edbrn@cyberportal.net <br />Hope u are the one I am looking for....ed..
