nighttrain
Thread starter- Joined
- May 15, 2003
- 2
I have a 25 hp Evinrude I believe to be a 1996 that doesnt run right after a fairly hard hit to the lowerunit at wot,very little prop damage and no visible case damage.it was a floating log by the way.motor had slight vibration after hit i attributed that to the slight bend in blade of prop but after about 6 hours(parked at camp) i headed for home and it dropped to about half power after 10 minutes or so.did comp check at home top cyl.= 90 center cyl.=115 bottom cyl.=85psi. removed head to check cyl. no apparent gouging or scoring and very little carbon.good cross hatching. any ideas? what are the 1/8 holes in each cyl. wall above the exhaust port? sorry for the length of this post. model #E25TKLEDC serial#G04107902
